Cam Angle Sensor (CAS) O-ring size
Turblown
220
7
Oct 9, 2003
Phoenix, Arizona
:thumb: FYI. This is some info I was looking for and thought it might be useful to someone else. I just replaced my CAS o-ring (gasket) because it was leaking oil. I found it in an o-ring kit I bought from Harbor Freight. I used some plumbers lube (Home Depot) to ensure a good seal. No more oil leaks.
CAS o-ring size is P30 (w=3.5mm, ID=29.7mm)
Felpro o-ring #420 is the right one for the CAS as well.
+1 thanks good info :thumb:
:talon:
Autozone also sells a small pack of "Distributor O-rings". There is one in there that fits perfectly and has worked for me. It come sin a pack of 8 I believe, varying in sizes. It's never a bad thing to have a few extra o-rings laying around.
Does anybody have the actual part number?
I noticed that the OEM o-ring is more squared the round. I tried a few round o-rings but they all still leak.
P/N sent to me by JNZ today for the CAS o-ring is MD622021.
Just FYI for future searchers.
Edit; Extreme PSI shows MD619648. Weird.
