Please Help, Leaking Cam Angle Sensor O-Ring
Logue
408
6
Sep 27, 2003
Tuckerton, New Jersey
I can't figure this out i replaced the o-ring i got the one from the dealer 3 times this week and it still leaks oil out from the cam angle sensor. Is there a certain torque for this or something i can't figure it out.
JJ
are there any marred up spots? gouges or anything? use a good lubed o-ring and a little RTV and you should be good to go...
Make sure contacting surfaces are smooth, and if need be, use a LITTLE sealant. Be VERY sparing with it.
i will try the lubed o-ringand some rtv sealant, the head was just rebuilt and hottanked, so it is very clean i looked and there are no gouges. There is a hole at the bottom where the o-ring sits but i looks like its supposed to be there.
JJ
