IIv SHaDoW vII
- 369
- 1
- May 8, 2007
Topeka,
Kansas
Alright, I am very close to buying a 2g gst with a 6 bolt swap. The guy told me the only problem with it is that it runs slightly rich. He said it runs rich because he can see a tiny bit of black smoke from the tailpipe under boost.
Mods - 6 bolt engine with no upgrades other than a garrett t28 turbo. He claims the engine is rebuilt with roughly 4k miles on it. The car itself has 90k on it.
My question is.. is this normal for a DSM? I have done a bit of research on running rich and have seen some threads that say its never normal and others that say its quite normal. I'd like to hear it here from the experts.
I'd also like to know of a good way to fix this? Can I fix it without buying a SAFC? He did have the coolant temperature sensor unplugged.. Could that have been causing a consistent rich condition under boost?
He said the only code thrown was from the coolant temp sensor.
What else should I check besides vacuum/boost leaks?
How rich does the engine need to be running before engine damage may have been done? I read a few threads stating that a prolonged rich condition will wash out the piston rings.. I am hoping the light smoke is normal because this makes me not want to buy the car. Also, remember the smoking is only under boost.
Thanks guys..
Thanks guys..
