Burning oil with no visible leaks(HELP PLEASE)
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
Hi guys I just brought a 93 tsi awd with alot of mods and ive had to add 2qts of oil less than 400 miles. Is this common on turbo cars or is there a problem. There is on visible leaks and very little smoke. I see very little smoke after idle for a while and a little when changing gears(but not all the time). check my profile for list of mods. Thanks fellas
Check your PCV valve.
Screws in at the back of your valve cover, on the left side.
Take the vacuum line off of it, then screw the actual valve out with a 14mm(i think)
Then blow and suck through it. It should only allow air through one-way.
You could also, crack it loose, then start up your car till it get to operating temp.
Then spin it till it's all the way out.
Then plug the end with your thumb, you should feel vacuum. If not, then you gotta plugged up line which could also cause oil consumption.
Don't quote me on this, but i think PCV valves are supposed to be changed every 30,000 km?
