bullseye gt30r...what A/R ?
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
you can either get it in a .48 or .63 turbine housing. What would the differnece between the two be ? Which would you recomend for a dd ?
.48 will spool sooner and have less top end.
.63 will spool a little later and have a little more top end.
There are even more variables. This is a very broad question but thats the general idea.
what other variables are there ? Do you think a .48 is good in a gt30r ?
"Bullseye's turbine housing is a .58 to .63 A/R Turbine Housing depending on what turbine wheel you put it in, i'm not totally sure which one it would be with a GT30R turbine wheel, but it's right around there."
Info ^^^ from Cragger who used to work at SBR.
You can look into PTE's GT3076RLE which is offered in 0.48 turbine A/R for fast spool but with cams, etc you might make the turbo suffocate.
I suggest the bullseye since it has a ~.60 A/R turbine housing, SBRs GT3076 turbo or FP3052.
Check out a thread called "Turbo Education thread" it has a lot of good info in it. It should be under FAQ. EDIT: Here's the link. http://www.dsmtuners.com/forums/showthread.php?t=199534
Also check out www.turbobygarrett.com
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech101.html
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech103.html
