bullseye 50 trim bolt-on
nkosi
320
3
May 17, 2004
montreal, QC, Canada
hey guys i just installed a bullseye 50 trim and it wont boost past 20 psi i check for leaks there is non but the turbo has a little shaft play but i dont think that would affect the spooling ...if anyone has experience with this turbo your input will be appreciated ...:D
Make sure you're doing the Boost Leak Test correctly. When you're doing it, make sure you're putting in enough air that is equal to or greater than the amount of boost you want to run. Example, the system may be able to hold 5 psi, but not 20 psi. Understand? Check those clamps!
