about bullseye power t04E 50 trim
anteversion
316
Jun 1, 2008
La Sarre, QC, Canada
So, im actually running a 16g turbo wich is at it max power right now. I want to upgrade with BC 272 cams and im interested about this bullseye turbo. i was wondering what you guys are thinking about it?? thanks
I have one sitting waiting to be installed. From what I read, it's rated to about 550hp and spools around 3.8k average. But that's only for the to4b compressor housing. I'm hoping it'll be better with the upgraded to4e housing. It will be a very interesting combo with the BC street/strip cams.
I've got the T04B version and, despite them sending me a faulty actuator (would only boost to 10psi), it works well. Spool seems to be a little slow at about 4,100, but maybe some tuning can bring that down.
Am using it with FP1x cams and have seen my power figures up by around 50-60whp with the change in turbo and intercooler. Pretty pleased with it so far.
The 50-trim compressor doesn't even flow 50 lb/min :) . It does spool to 20ish psi under 4K as reported by many.
But you can just get the BEP housing (same as what's on that 50-trim) cut for the holset hx35 and install a used holset h1c and get faster spool and the same flow. With the same cost in oil lines. No coolant line costs. And a far less expensive turbo. Or you can spend a little more and get a used holset hx35 have 52lb/min flow (about 2-3 more than a 20g, 50-trim, h1c) and have the same spool speed.
. . . Here I go promoting holsets again.
hehehe holset rulez :p
will get mine very very soon
so far i hear only good things about it , just need to shoot more dyno's and time on the track with it, by then i guess holset prices might shoot up due to dsmers demand hehehehhehe
