building 420a without boosting
Cfrasher
May 28, 2009
MT. Washington, Kentucky
My name is corey and i am new to DSM. I recently bought a 95 Eclipse GS and i was wanting to build it up a little but i do not want to run turbo. The car already has a cold air intake and a full catback exhaust. thats all it has everything else is stock
It's also gonna be my DD. I want it to be fast just without boost
any suggestions
Thank You!:)
i have an idea of what i wanna do
Aftermarket headers
Cam gears Cam Shafts valve springs intake manifold
fuel rail
throttle body
any more suggestions
thanks again:)
Weight reduction, anything you dont need or want you can remove. If you wanna get into the motor a little a quick and easy port and polish job on the head with some cams will wake it up.
Seeing as it only has a catback you could do a header as well. Are the 95s OBDII? If not you can pull the cat and put in a test pipe
their is a guy on here who i belive is the fastest n/a 1/4 mile and he runs around 13.0 look at his profile
Bulletdsm. Mark has the fastest NA 2g Eclipse ever
there's good info here in the 2g NA sections or if you want a TON of info check out 2GNT.com, we've got tons of info over there.
Technically they're OBDII, but it has some oddities. Pulling the cat for a testpipe will usually set off a CEL although I've seen people get away with it and never have a CEL. The mopar ECU's are a little odd compared to the mitsu ECUs
