kyler021
- 252
- 192
- Aug 29, 2023
Pasadena,
Maryland
Hey all,
I'm having an issue with my car bucking/surging in 3rd gear during a pull. For context, I just got tuned by McKenzie Lange of LangeTuned. We finished up the tune around the beginning of October. I'm on SD, have Evo 560cc injectors, Walbro 255, 16g turbo, and FMIC. I believe my build profile is current, so you may see more info there.
We had an email convo before the last tune he sent me, and it seemed to me that the car would overboost (~27 psi). He turned down the wastegate duty cycle, and that fixed it. After the duty cycle was turned down, I think I remember the boost starting around 20psi and ramping up to 23psi near redline.
When I look at the boost gauge when doing a pull, I see it goes up to ~25 psi and possibly higher when it starts jerking and bucking. I did notice that it went full lean when it occurred.
I have changed a couple of things since the final tune. One, I put an STM SD Intake on. And two, not by choice, but my AEM FAE Wideband that goes along with my X-Series Wideband failed AGAIN. So I threw my old Bosch Wideband in there. I'm gonna be honest, I didn't change the wideband scaling in ECMLink when I switched the wideband sensor. So that is not great. But I noticed it was pretty close to the expected AFRs.
My initial thoughts are:
The STM intake kinda pinches one of the MAC wastegate solenoid lines. Not really pinches to where nothing can get through but it does contact the vacuum line and not by a small amount.
Omni MAP Sensor (Again)
Boost Creep?
I added 2 logs. One from today, 10/28 (normal) and one from yesterday morning (10/27) where I could actually catch the jerking. The only reason I haven't emailed my tuner yet is because it's intermittent. Some days it's normal, and some days it's not. Today, it did it one time, then the rest of the time it didn't do it (couldn't catch it in the log).
Any ideas guys? Thanks!
Boost Creep?
