datalogging in 3rd or 4th gear?
yo2001
323
Feb 29, 2004
Birmingham, Alabama
Who prefers tuning the car on 4th gear rather than 3rd gear via datalogger/AFC combo? I tuned mine 4th gear because if I tuned for 3rd gear I get crazyy amount or knock in 4th gear.
I have trouble tuning in fourth, because that requires me to be going 120+ mph at the end of the pull.
If you are seeing a bit difference between third and fourth, then you might want to consider if you car has any efficiency problems or anything.
Runs in 4th gear can be read easier, however running 4th gear to redline is fast!
Going that fast has been problem. :D I've been shutting down around 6000 rpm in 4th.
I do have efficiency problem. stock SMIC, stock IC pipes (next thing on the mod list) and EVOIII 16G at 18-19 psi :shhh: Do have 550's though. Thanks for the replies
But even with FMIC, would you not have more knock sum in 4th gear than 3rd gear due to load? :confused:
