BROKEN WIRE EMERGENCY - 2g coolant temp sensor, ANYBODY CAN HELP ME
rabenne
1,803
843
Apr 21, 2006
Racine, Wisconsin
My coolant temp sensor wiring is all messed up... can someone with a 2g please check what wire colors are for the coolant temp sensor (at the sensor on the thermostat housing), and the other sensor that is screwed into the thermostat housing. One is a single wire I believe, but need to know what color it is. The other is two wires and I need to know the wire colors, and position (left or right) on the black plug connector. Please let me know if you have a chance, THANKS!!!
Well, I am in the same position as you two.........
how ever the plug sensor the wires are black, and black with white stripe not sure what goes where, and for the single wire i do believe it is a red wire.(i just used a spade connector for this one)
