broken half shaft bracket bolts
Er1kGgsx831
Jan 3, 2015
marina ca, California
This is my first time running into this problem
I have a 92 eclipse gsx awd .. i have broken a bolt off the bracket that holds the half shaft axle.. i been tryin to figure out the problem .. this is the 3 time i have broken bolts off the off the bracket
Plz help me!!!
Donnie is right you need the oem bolts. I learned this the hard way LOL.
Thanx..and everytime i began to step on the break i hear metal to metal hitting n that causes to break my axle half shalf bracket bolts
Has your air conditioning been removed? The a/c compressor bracket is where the axle bracket bolts go thru providing the proper alignment with the trans hole. If that is gone, it makes the alignment off putting some extra stress on the bolt heads.
Noo.. but it doesnt have the ac compressor bracket.. is their away to fix that or do i need to get the ac bracket???
In order to get the spacing right you need the bracket or if someone has one handy to measure you can replace it with stacked up washers.
Use an easy out. Or just drill it out to the point where the left over metal breaks easily. Its a PITA, but it works.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
