Broken Exhaust stud repair
Broken exhaust stud repair.
I had a cylinder head come to the shop, it had a bad drilled exhaust stud.
Whoever tried to remove the broken stud before, did not do the best of jobs.
Part of the old stud was still in the hole. Along with part of an EZ out.
I took a die grinder with a carbide burr and ground out the stud and EZ out.
I was left with this for a hole., I knew a simple Heli-coil would not fix it.
So I made a bushing to repair it.
The head casting was drilled and tapped for a ½ x 13.
Next I installed a set screw. You could also use the threaded part of a bolt.
Use “Green locktite”
After about an hour, the locktite is set up. Drill the set screw .2660, then tap for 8mm x 1.25
Next fit the stud.
The customer should not have any exhaust alignment issues of the exhaust manifold now.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
