Broken bolt removal - Mixed methods
I have a broken bolt in a Honda exhaust header.
It is broken off about 1/8" above the flange.
Just enough to get a bite on it with some vise grips.
First thing I am going to do is heat it up with a torch.
Make the area around the broken bolt glow.
At this point , work quickly, lock the vice grips in place, and wiggle, DO NOT try to superman the broken bolt out on the first try.
Soak in WD-40, wax, engine oil.
It will smoke and stink, and watch for flare ups.
I was able to get about a 1/4 turn befor it locked up again and the vise grips kept slipping off.
Time to try something else.....
Get a nut that just fits around the broken bolt.
I used my old stick welder and welded the nut to the broken bolt.
Get a wrench on there, and keep working the bolt back and forth.
I was able to apply more force applied to the broken bolt and get it out.
Now with the broken bolt out, I can see why it broke.
A couple threads had gaulled, and sripped some.
I will let the header cool, then install a Heli-coil.
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
