broke fuel line
Firstly, before anyone can answer this, you have to specify what material broke and where. Hose + clamps on non-barbed hard lines is a leak waiting to happen.
I had the same thing happen to me when I installed my 255hp. I just got a new metal line and fittings and attached a union instead of using fuel line and clamps. I haven't had any leaks so far and I run e85 at 23+psi with a rewired 255hp and 43psi base pressure. I wouldn't trust a fuel line to last long with high fuel pressure.
I did the same thing by the filter a long time ago and tried it 2 ways..the first was with a compression fitting (which killed fuel flow a bit), then the second was hose clamps and fuel line until i got my -6 feed. It took 3 clamps tightened with a 1/4'' ratchet to get them not to leak, but the flow picked back up again :)
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
