Broke both throttle adjuster screws- help
FrostBite
97
Dec 6, 2003
Stockton, California
I wanted to tighten my throttle cable since it was idling at like 500rpm so I went to unloosen the 2 bolts that hold the throttle cable in place on top of the intake manifold.....and....both heads snapped off. So now the threaded parts are submerged into the holes with no way to grab them or get at them. I dont know what to do besides drill them out but then ill probably mess up the threading in the holes. Any ideas?
I'm pretty sure he means the bolt broke in there, I suggest you go ahead and drill it out. I had a bolt break on my idle air control valve and I had to drill that out and it was fine......
do u have enoughspace for a drill in there? if so takem out with a drill-out from sears(make sure you use pb-blaster before drilling them out, spay the bolts with pb-blaster aLOT and i mean alot. for two three days
