Broke A Piston Wrist Pin.
Like I stated many times over CP pistons are awesome! Most of these guys get on here and run their john brown about how cp is not a turbo piston and they only made pistons for NA back in the day. The key statement is BACK IN THE DAY. Times have changed just like back in the day weiseco was the worst piston IMO because of experience to run in a honda b-series engine because of this experience they are not my choice and never will be but some of these guys that will chime in on my thread and bash my choice of piston that I purchased with my own money that's just plain stupid. Thanks ceedawg for that link! If I had asked wether I should use CP then that's a different story:rolleyes:. Cp is a custom piston manufactorer and as explained by them they only make pistons to specs by vendors request. That is why race engineering 4g63 pistons differ from slow boy and slow boy pistons differ from brian crower and so on and so on. CP made my pistons to my specification . A job number was assigned to my specific order. I had the works put into the piston. they in turn sent me a spec sheet with all these freaking measurments on it just in case I wanted to send it to another piston maker they can give me something similar. compression ratio was also spec according to my liking 9:5 to 1 valve pocket cut was my custom spec and so on and so on. Now here is the thing if the piston hits the valve it not cp fault its mine because I didn't calculate the valve pocket to be cut deep enought hey I take the blame. The wrist pin broke hey I should have told them what my Hp goals were in the begining I would have gotten the pin to suit my applications.
To sum it up people chose what they are comfortable with in my case its CP;)
I'm tired of watch the people I know do wood work and fail, but You sir, You have talent.
I wish I knew carpentry like you do. GOOD JOB!!!
Lol I guess nobody will ever understand what "Custom Pistons" really means.
They don't care its all about selling a product and what I mean is some vendors gonna speak bad about cp to push a piston that a manufacturer has agreed to let them sell in their "machine shop". its their job to down the competitor product! Kiggly run cp and ran the fastest time at the last dsm shootout you know what's sad he's fwd LOL!
What are you going to run for a headgasket/head stud setup?
Oh my goodness you had to ask the million dollar question:p well if it benefit the board let me say this I have run just about every head gasket out there as seen in this pic from mitsu mls ,felpro permatorque ,cometic and the Freaking list goes on all ran with maperformance h11 studs still push coolant despite claims of sealing like no other so I spent months studying head gaskets and type. Long story short the only one that solved the issue was the Hks stopper with the h11 studs. I have built several engines for others with same success as mine. Coolant push when detonation occurs the stopper gasket handles u.expected detonation well witch save from knocking original seal of headgasket loose. So to answer your question Hks 1.6mm stopper ftw!
This is the felpro permatorque head gasket you knotice the ripples/waves in the metal this is from episodes of detonation which came from different grades of e85 from different gas stations the thin metal in the gasket took the hit and lost its seal very quickly. This was a couple years ago.
DAMN!! shit was making music with that HG.
I had to ask once I noticed the block didn't have any
o-rings put on it.
o-rings put on it.
Yeah when I broke the engine down I measured the stopper thinkness and it was about .008 and the oring protrusion was measured at .005 therefore the gasket provided the seal not the oring. So on those other builds for two buddiesof mine I eliminated the oring altogether with success.
Yeah when I broke the engine down I measured the stopper thinkness and it was about .008 and the oring protrusion was measured at .005 therefore the gasket provided the seal not the oring. So on those other builds I eliminated the oring altogether with success.
I just read up on it. Looks like it's worth the coin.
Man this car should be back on the road by now!
Na man it will be a minute can't rush doing it right. Once engine is done and installed I have to have it towed to dynolab to get a ton of custom fab work done:p
700hp on a fwd is going to simply be.................:aha:bananas
Hyabusa interstate killer:D here is the heart of the power as I was told. Comp billet CT4 6765 .82ar extended tip triple ball bearing unit HF turbine wheel we shall see.
