Breaking up under partial wot to full wot
StreetTunedTSi
56
Apr 23, 2009
East Petersburg, Pennsylvania
OK, so the problem im having might not exactly have to do with the safc2 but, i tuned the car my self i read up on it a decent amount, car ran fine for a while, but now i cant got wot or partial wot without the car breakin up alot, the a/f ratios read between 10.5-12 @ smei to full wot, but car runs fine under cruising a/f stays between 14.6 - 15.3 and no breaking up, should i set more ne points?
my low settings
1k,0 2k,0 3k,-7 4k,-6 5k,-6 6k,-5 7k, -4
high settings
1k,0 2k,0 3k,-22 4k,-20 5k,-18 6k,-16 7k,-14
low throttle is @ 25% hight throttle is @ 75%
Correction: reads -7
karmen sensor type, 4cyl with arrow up selected
you can look at my part set up, im still on the t25 set up not 16g.
Thanks guys!!!
If your running stock inj, then your high settings are takeing away to much fuel. I'm running 580s and your settings are not to far off mine on the top end. I'm not sure how your AFRs are Reading what they are.
is it breaking up around 2k at all? Also make sure your MAF isnt dirty try cleaning it with Mass Air Flow Sensor cleaner and see if that helps. Check the PTU plug
yea i deff should ###### change out the plugs and wire, deff the coil pack 88k on my car and its deff the stock one, but i did my plugs maybe a month ago with oem ones and i gapped them a little colder than factory i went with .032 instead of factory .034 or sum linke that,pep boys wires done with plugs. not the best but they meet oem spec so i guess the wires should be fine
