Break into 13s? Possible?
trapspeed
1,187
3
Jun 16, 2004
Sacramento, California
Just got back from the track. I'm pretty satisfied with my runs but I know I can do better. I just wanted to know if it was possible to break into 13s with better driving. Well, here is what I did on the run.
R/T : .266
60' : 2.557
E.T. : 14.310
MPH : 101.367
My mod list is on my profile. :) Thanks.
R/T : .266
60' : 2.557
E.T. : 14.310
MPH : 101.367
yep man that 60 is horrible. trap speed is 13's for sure. Slap on some drag radials and tell youreself who cares what happens to the car ;)
Cool. I've been practicing and no matter how fast I shift it always seems like my 60' is way up there. I think this is the best 60' I've gotten to date. Kinda sad. I have brand new Falkens on there and lowered the air in them. Hm.
I don't think it's slow shifting that is hindering the 60 foot time. It is almost definitely your launch.
That FWD lauch will get ya. Work on the 60ft like there's no tomorrow and you may see 13's. :thumb:
Any suggestions on what I should try to launch at?
Do you slip the clutch out or drop it?
My buddy in his nitrous sohc honda ran 13.05 at 101mph mph.(on slicks)Run drag radials (555R or BFG) and i bet you can get that 60' down to 1.9 or so.
Being a fellow FWD'er i would say the best strategy is to slip the clutch. If you simply pop it out, you'll either bog or spin all the tread off your tires. With dsmlink I set my stutter to 4500rpms and just slip it out a little and once the clutch really starts to grab, i floor it. Of course i have an lsd which helps. Others may disagree with slipping but ive found it to work best for me. Try both and see which you like better.
Thanks for all the help everyone.
I decided to invest in some drag radials or slicks. Anyone have recommendations?
I'll probably pick up some 16" rims and just slap the slicks on those.
yes definitely slip it out. if you tried both i guarantee you that you will feel more grip while slipping it out.
yea, that trap speed is definately into the 13's. think of it this way, for every 1 tenth you take off your 60', you take 2 tenths off your final et. such as
14.3 w/ 2.5 60'
if you can run a 2.3 60' then theoretically you would run a 13.9 :thumb:
so yes, you are definately able to hit high 13's. just work on the launch, practice practice practice. my best 60' is a 2.3 and that was my first night launchin with my new clutch.
so just practice, you will get there. :thumb:
Falken Azeni's are not a good drag racing tire. The sidewalls are too stiff, all you will do is sit there spinning your front wheels.
However, when you go to turn, their beauty will shine through :)
98spydert said:
Nice Adam, you'll be there in no time with that trap speed, especially when you open that 16G up with fuel mods and a FMIC :thumb:
Hehehe. I am picking up some 550s next week. FMIC will be a while, though. I'm trying! :)
I suggest slipping. I don't even dump the clutch in my AWD. I slip it very quickly, but I don't dump it. You don't want the power to come on all at once. If it does, then you will spin wheels. You want it to come on as quickly as possible without spinning wheels. It takes practice. Hell, I can't even launch my AWD like I should; that takes more practice than people think.
Holy crap that 60' is horrible! thirteens is definitly possible with your car. My friends fwd honda with an lsd nitrous and slicks does like a 1.8 60 foot. I have yet to do one of those in my car. I can't believe it. It's possible man practice helps but I think it would be best to try out some different tires. :thumb:
Yea. Im looking for a pair of Nitto 555s Drag Radials.
I have bad boost creep so anywhere from 15-20. Lol.
Drag radials and a clutch that can handle the power is a must...I personally slip my clutch also. I use relatively high revs (5k). let the clutch out rapidly half way. Control wheel spin by feathering the gas till I feel the wheels start to grab. Then I let the clutch all the way out and hammer the gas...Takes alot of practice but once you get it 13's is not a problem...But to do this a strong clutch is a must. :dsm:
I didn't see a clutch upgrade on your mod list. If you're running stock clutch still, I would definetly do that next. That should help a lot with launching. :talon:
Would I actually feel a notice in power with a new clutch or would getting one just allow me to launch higher?
Makes your car feel a lot more "solid" at the least. You're launches will improve a lot and shifts will be extremly solid. You'll only feel a power difference during a pull if you're current clutch is slipping. If it's not slipping, it's probably going to start when you make some more power and keep racing. My stocker died just with the T-25 back in the day, I never did a 1/4 run or hard launch with my car :(
If you plan to do a lot of 5k launch with sliping techniq, your stock clutch will not last to long. When I installed the Act2600 and Act lighten flywheel I did notice that it grabs better in every gear and better throttle responds as well. Be prerpare to learn the clutch all over again though, they aren't easy to drive.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
