Brand New GST owner Need Help Building
NathanCarlK
53
May 17, 2012
Ulysses, Pennsylvania
Hey guys, 2 days ago I got a 1998 Eclipse GS-T Spyder. Everything is stock, and it has 62,000 original miles. Everything runs amazing and its spotless everywhere. Some grandmaw owned it! Woot! I'm going to start going to work on it here and what I need to know is what would be best. I don't want to cut corners but its hard to get straight answers. Some say cold air intake, or exhaust system, others say to take the heavy hood off and put a light carbon fiber one on, others say put a chip in it. Where would be the best to start off? It is FWD so i'm not looking to get above 400 hp. But I would love to be pretty close. Let me know what you guys think. Thanks!
No, the only awd spyders are ones that have been converted. Mitsubishi only offered them fwd.
So what is the difference between a spyder and a regular gst? I can simply search it,but since we're here. Also,what step you should take next depends on your overall goal for the car. You don't wanna jump into one thing and realize hundreds of dollars and hours down the road that it's not what you want
^ A convertible top. :p
OP- Start with maintenance. At 60k your well due for a timing belt and a good tune up. Look into free mods before purchasing anything as well.
^ A convertible top. :p.
I always thought so. I just didn't know it was that obvious.LOL
OP- You sure this was off a grandma? I can only imagine it was either a grandson "selling" it for his "grandma" or this belonged to a cougar.:thumb:
No way I see Ms. Daisy driving this LOL
Just like what everyone else is saying, I would agree with maintenance. Timing belt is a good start along with the balance shaft eliminator. When i got my DSM I went and swapped the timing belt straight away. When i pulled off the timing covers I saw the balance shaft belt broken and frayed. It was about to get sucked into my timing belt and ruin my motor! Could have been way worse if I had started upgrading only to have something simple destroy the motor.
The sound is amazing, I love the feeling. Right now I've got $500 but thats after putting $400 into a new cd player/ speakers. The previous ones were pretty bad. : / How much would a car like this be worth? I think I got a good deal on it, but you guys are the experts!
Alright, Well so for starts a blow off valve? Where would be the best place to pick one up. I live in the middle of no where, the closest walmart is an hour away. Is there a perticular one that has a good reputation. Also can I trusted used? Thanks!
Hmm, I dont think Walmart is the place to go for a BoV. I would suggest a 1g BoV. tested and true, and cheap. ~40-60$ here on tuners for a used one. Do a Boost Leak test as well. Good find on the car, low miles, it would go for ~5-6k here in Cali
Buy a uncrushed 1g blow off valve from the classifieds here for around 30 bucks. Once you get to a point where you need it to hold more boost you can crush it, which you can ask about later.
A great first upgrade would be a 14b which can get you to 300hp with fuel mods and a upgraded exhaust. You will need a install kit which isn't horribly expensive.
Next I'd buy a ebay intake and put on a K&N filter.
If you want a exhaust I'd get a after market O2 as well. Which may come in handy later if you decide to go with a 16g... because they will creep bad with out one.
A CF hood is beneficial but is a waste of money unless you are really really needing/wanting to save weight. Sure the stock hood is something around 55 pounds and most CF hoods are slightly under 10 but you will also need hood pins, some people never have problems with the latch they come with but honestly it is not worth the risk. Some people have them fly up at just 45mph.
If you do plan on getting more fuel some evo injectors, a wally 190 (since you won't need a FPR and you seem to be fine with around 300hp) will be fine for your goals. You could even get a evo fuel pump if you can find one cheap.
Since you are a 98, you can get your ECU flashed for a tune. If you ever do fuel mods you MUST tune your car.
Don't forget before turning up the boost with a manual boost controller you should ALWAYS have a boost gauge and a wideband. Being able to monitor what is going on is a MUST.
Now where can I find places to help me with this. I'm new to cars and there dont seem to be any shops around here that will do anything but body work with a "tuner" the walmart thing was a refrence to how far in the middle of no where I live. I wasnt planning on going to wally to tune my car for me.. ROFL
Is a greedy Type s good? My friend reccomended it to me. Said is sounds real mean.
Do a boost leak test (BLT) to see if your'e BOV is even leaking in the first place, it's also part of preventative maintenance
2G Turbo DSM Boost Leaks -How to test and fix
By the cool BOV whooshing sound I assume your'e talking about venting to atmosphere with an aftermarket BOV. Unless cool sounds over performance is your thing... Research that idea first, it's not the best for a stock setup
It's a nicely taken care of car, good find :thumb:
Welcome to the site
Very cool car! Im fairly new to the site as well and scored a 99 GSX with 51,000k original miles.. Kinda have the opposite problem as you tho.. The guy that sold me the car modded the heck out of it LOL.. But good thing is, all the work was done at a shop. Im starting to put stuff back to stock and then start over with some different mods that are not so wild here in Cali where smog is not your friend hahaha.. But with all these quality aftermarket parts he still never got a Boost controller, or gauge... would any one recommend a good boost controller and gauge that do what they are supposed to, and don't cost a grip$$?? Nathan could probably use the info as well if he plans on adjusting and measuring boost in the future... :hellyeah:
Try not to get the cheapo eBay MBC which is the bleeder design. Just keep it simple with the ball and seat design. Or go DIY (you own a DSM right?) and make a ball and spring MBC from the hardware store $10. Awesome.
Homemade MBC in the works... - Turbobricks Forums
^Favorite link shows great pictures and most importantly the hole to drill which a lot of DIY guides miss
what is better bleed of or ball and spring MBC? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
I have a Greddy boost gauge. I dig it.
Sorry I can't comment on any others, but there is plenty info on boost gauges around here. It's like the first mod anyone should do...
