99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
Well, if you aren't using AN fittings, then I'd recommend that you use regular rubber vacuum hose with something on the end to clamp it down tight (I've always had great luck with safely wire). An airtight seal is more important than the way it looks.The guy above did the same. Should I use heatshrink? I think it looks pretty good in my opinion. I was going to use hoseclamps.
What you have for the crankcase vent hose and overflow bottle are OK. But the connections where there is high pressure/vacuum, it's probably leaking.
