BoostedBeaver
Moderator
- 957
- 291
- Aug 15, 2009
Augusta,
Georgia
This is a 1g BOV I bought from a member on tuners. I received the BOV and all seemed well. I bought this BOV to perform the Dodge Mode (Video to come), so I did just that. After modding the BOV I set up a little contraption of T's and hose to make sure everything was sealed up and to check the set screw in the bottom of the BOV to make sure it was sealed. During testing, I found that the BOV is leaking air out of the discharge tube when pressure is applied to the bottom nipple. This leak can be altered by moving the shaft side to side (seen in the end of the video) but never stoped. I know there must be a seal that goes around the shaft and I am guessing that this has went bad, but I am no genius and would like your advice.
1G Blow off valve leak... Not the usual kind - YouTube
..I'm a bearer of bad news I know..
I will quit trying to get you to test the BOV and let you get your car back on the road. Good luck to you and I know you will be back boosting soon.
Thank you for clearing that up for me. Just by this thread it seems that this will be a problem that many will have, but some will not.
