*Bov going of in neutral*
way2slowtalon
147
Oct 24, 2004
Newington, Connecticut
WHy would my stock 1g BOV be going of in neutral, when im not venting to the atmosphere? It even does it at 2000rpms. Is it leaking or something else?
Because your 14b spools very fast. It doesn't have to be under a load to build boost well. It't not your 1G BOV, its the small turbo making this happen. On my greddy type s and tial I could never get them to do it with my 60-1. Even off the two step.
Steve
Steve
But i have a Big16g ported/ with a 31inch FMIC.
I can make my 50 trim spool enough to let the valve go. I guess you'll need a much bigger turbo to avoid this side effect. Hell most people want their BOV to go off in neutral so they can make "cool sounds" at stop lights ;)
on my 1st gen revving it would make it open had no leaks pressure tested that thing every oil change
