Boost leak test leaking air into valve cover on my rebuilt engine with 50 miles
Late to debate, but you want to feel for a boost leak not just listen. Tail pipe, intake manifold, etc. If you really want to get tricky you can make your own smoke machine with the help of youtube, then pressurize for boost leak test with the system full of smoke
If the boost leak test is inconclusive then compression test. Those numbers will indicate if your rings or head holds pressure.
Most of the time they junk used 14b's or abused used td05 turbos I've run from a junkyard or just heavily used will leak pressure back into the crank case from the cartridge. Nothing like popping the dipstick out and shittting yourself with oil and smoke everywhere
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
