MrNeedles
- 79
- 0
- Jan 17, 2009
Chicago,
Illinois
So I tried to start my car today after putting it back together. I had put a 1g head on it and just cleaned up the engine bay. It will start but won't idle. I have to play with the throttle to keep it alive.
I did a boost leak test and the system holds no pressure. I then tested from the throttle body elbow and there were no leaks, that end of the system is holding pressure just fine.
I then tried to pressurize the intake manifold side and the system held no pressure at all. Nothing registered on my boost gauge. I checked everywhere and couldn't hear any leaks and could see or feel any with a spray bottle. I had the motor at tdc as well.
Could someone give me a little help here?
. Fml. I'll keep this updated after I swap the gaskets.
