no boost leak
hotT0Male
Jan 22, 2003
only getting 10-11 psi. cars pretty much stock, just put it ngk plugs and accel wires.
t25 turbo
greddy type-s bov
no manual boost controller
i did the boost leak test, didnt hear any hissing at all and im only getting 10-11 psi of boost. anyone have any ideas to help me out? thanks
You need at least a manual boost controller. This will allow you to exceed stock levels.
WARNING! Do no install a boost controller with out an aftermarket boost gauge. The factory gauge is not acurate and its sort of estimated by the ECU. You could cause serious harm to your car. From what I read keeping it under 15psi in stock config is the way to go.
If your timing gets pulled from the boost level turn it back down. A datalogger is nice to see if your knocking and harming anything.
