Helpppp no boost leak but no boost
97GsXfreak
137
Nov 15, 2004
Berkeley Heights, New Jersey
Mods: sbr 20g, 680cc injectors, pump, afpr, hallman bc, and all the other stuff.
Problem: I cant boost over 10 psi. I checked for boost leaks and i fixed the little holes but it didnt help. I took apart my turbo and put sealer around EVERYTHING. Still the boost doesnt go above 10psi. I unhooked the boost controller from the wastegate nipple and the boost sky rockets. So i am thinking the problem is that the wastegate is messed up but when i connect the turbo to the wastegate it sticks at 9psi where the wastegate is probably set at. Any way to fix this??? NEEd help asap! Thanks
