Boost leak at throttle body cable
JohnCIV_Talon
Banned Member
340
Mar 22, 2007
Sanford, North Carolina
Ok so I did a boost leak test today and found that, that is where the leak is at. Its wierd becasue its the actual throttle cable area. The thing in a whole moves back and forth a little and if moved right the leak stops. Its a pretty significant leak. What should I do?
Are tehre any quick fixes? Like using some sealant for the time being, Im in college and leaving soon again and I have no time until summer. So is it possible to quck fix it without even taking it apart. I plan on buying a 1g during the summer.
Unfortunately...no. At least none I've found or could think of. Using sealant or anything similar, you run the risk of causing any number of problems. IMHO the TB is not a place you want to be randomly throwing sealants at.
By the time you remove everything to get to the seals, you're 95% of the way to just replacing them.
Even then, if you use the o-ring method (using the existing seal "cans" and putting an o-ring in them)... you'll run the risk of still having a leak depending on how bad your cans are and how well your o-rings will seal. I know this as mine are starting to leak again... and I thought I did it pretty well. :rolleyes:
If you do it yourself, find the actual replacement seals rather than digging out the remaining rubber and popping in a hardware o-ring. Just my opinion :)
EDIT:
If you don't have any other boost leaks, it SHOULDN'T be to big a problem, depending on how bad it's leaking and what your boost is, etc. Again, that is just my opinion without knowing your situation, so take it for what it's worth ;) With that said, it only took me like 3 hours to do the whole thing (car running to car running again), and I was moving slowly. Even with the one seal starting to leak again (due to old bent up "cans" or not enough grease), it's still way better than it was.
I completely agree with calan. I'm not aware of any quick or temporary fixes that will allow you to avoid disassembling the TB. But as mentioned it generally doesn't cause any severe driveability issues. If you plan on replacing it with a 1G TB this summer (is that what you meant?) then it should be ok to leave it be until then.
Are you getting true violent fuel cut or just some stuttering and bucking?
kmoore, I'm curious if you noticed any difference while driving the car since you replaced yours? Mine are leaking bad also.
I know for me there was a significant difference. If you are leaking enough you can change your air/fuel ratio and loose plenty of boost pressure. Once the seals are replaced run a boost leak test and make sure you aren't leaking anywhere else. If you had a huge leak at the throttle body shaft seals, you may not have been able to hear or find any other possible leaks,
