boost leak and other question
Status
Not open for further replies.
talonman2011
Banned Member
20
Jan 30, 2011
listowel, ON, Canada
hey everyone ok have a few questions. Ok i built a boost leak tester i have a leak around the blow off valve now where its leaking it cant be fixed . So i am going to buy a new BOV now i want one the vent in the the air can i do that. Theres a line that goes to the intake and a big line that goes to the turbo intake and one of those mini filters on the intake and cover the big hole on the turbo intake and just go stright BOV.
Now this question has to do with my other post. when i am driving hard like hard on the gas and i hit about 5500 to 6000 rpm its like the car shuts off. First its like its starts to struggle like jumpy then its like it has no power and hard jump like shakes the hole car if you no what i mean i will post a video if you guys want bit its like the car runs out of gas or something now it just started recently
Im assuming that your saying that you want to vent your bov to the atmosphere. Thats a no-no. You can get plenty of sound with having the bov recirculated.
Having it vented to the atmosphere combined with a boost leak is probably the cause of the car shutting off.
Also, post your mods in your profile. That will make it easier for us to suggest what is going on with your car.
What is wrong with the BOV to say it needs replaced? Unless you run a GM MAF in blow through (mounted post BOV) or are on a speed density setup then you need to recirculate.
ya no i don't have it done now and the car is doing it car is stock but ya on ebay there are BOV that has like a wide mouth i want to use 1 of them can i do it.
What is wrong with the BOV? Just FYI, usually a cheap product on eBay means it usually sucks. There are some exceptions but a BOV from eBay will most likely leak due to a very poor diaphragm design. Also we have no idea what BOV design you are even talking about so it's better to post a link.
If you want a replacement for cheap go with the stock 1g BOV. It will hold all that you can throw at it right now AFTER maintenance and proper mods needed to run higher boost.
it look like someone put a 1g BOV on my 2g so that welded to the bottem of it and its leaking on the weld but on same note i want to dress up my motor a bit so i want to go super loud BOV and nice looking
I gave you a warning for grammar. Don't post like you're doing from this point forward.
I don't get this form everytime i post i get in trouble i check my spelling its fine i don't understand whats wrong with my grammer.
Please take a picture of the issue you are describing and please type properly. I cannot understand what you are even describing for most of what I have read.
what do you mean??????
And grammer what do u mean i asked a question i am getting answers back with question i have to answer i don"t see what the problem is. Only this i see wrong in blow off valve (BOV) this is a DSM form with turbo cars of people dont no what BOV mean thay better sell there car
Is English your first language?
If so, capitalization, spell-checking, and punctuation should be no problem for you.
It's a rule. You agreed to it. It's not up for debate.
You may want to look at our rules about conflicts with mods in open forum, too.
It looks like someone put a 1g BOV on my 2g so that it is now welded to the bottom of it and is leaking on the weld. On the same note, I want to dress up my motor a bit, so I want to go with a super loud and nice looking bov.
See bolded for how it should look. All we ask for is grammar, punctuation, spelling and non-runon sentences.
Additional warning for your ill-advised edit.
FWIW, DSMTalk would have banned you by now. ;)
Sorry i am canadian i just red what you think my grammer problems are and it looks fine to me.
so pritty much it looks like i am going to get the boot soon cause i am canadian and dont talk like you americans
well i guess boot me i don"t no i had a question and then get screamed at and don"t no what i did wrong.
My spelling is check by spell check so i don"t no sorry i guess.
No one is here to scold you, just to advise you.
Repost your original question clearly and with pictures so that we can see what it is you are talking about.
If you speak English, you could be from goddamned Djibouti and do better than this. Thread closed due to willful disregard for our rules.
Now, I'll be watching you.
Status
