BOOST????? Is this normal? Could this be my CEL problem?
twadman
Apr 22, 2008
Franklin, Tennessee
Ok so I changed the brakes on my car and I have had the CEL on for a while, it a fuel trim malfunction, and when I took it out for a drive i noticed the boost was not sitting at 0 when i was not pressing on the gas or in neutral.
This one is cruising in third at about 45 miles an hour. Just coasting.
This one is coasting in neutral at about 45 miles an hour.
This is not normal is it? Does this mean boost leak?
no not normal at all. and i have the autometer gauge. it drove alot better before i let it sit for a week because of this light coming on.
If the car is running, that's perfectly normal.
Since the boost gauge is tapped into manifold pressure it will see engine vacuum, which is around -20 inHg at idle(many factors will change this) and will constantly change at cruise depending on pedal position, rpm, and load.
It should sit at zero when the car is off.
When off ^
Its idling kinda wildy to. And its my boost gauge on my cluster that is doing it to.
The boost gauge itself is off. If you subtract 2.5 psi(~5 inHg) from the other readings, you're pulling the correct amount of vacuum given the circumstances.
The only way to know for sure if you have a boost leak is by doing a boost leak test.
Ok thank you for your help. I just thought this meant a boost leak. Ill have to do a test then.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
