could this be my problem, pics included
i have no idea what it is, it looks like a bearing or something covering it, i cant take it off i think
Go and buy a new oil cap... they are like $12 for stock.
Here is one for $8.39. Though your junk yard would be your best bet if you really want to go cheap (cost wise, not parts wise).
http://www.247-parts.com/additem.ww...0.10&clientid=247&cookieid=1MJ0KSFWX1MJ0KSNIR
If you cannot get the cap off, then perhaps try to get it off from the underside. To do this, it will require taking the valve cover off. And that would be a great time to replace the valve cover gasket, spark plug gasket, and that half moon crankshaft plug. It is only like 14 bolts which require ~2.5 lb/ft of torque (which is just a bit tighter than finger tight) on each. So if you take the valve cover off get a gasket kit and some Silicone RTV.
Gasket kit with Sparkplug and half moon plug ~$29
http://www.partsamerica.com/Product...L&mfrpartnumber=VS50434R&parttype=107&ptset=A
RTV ~$3.68:
http://www.partsamerica.com/ProductDetail.aspx?categorycode=3289&mfrcode=PTX&mfrpartnumber=81160
Here is a vfaq on replacing the valve cover, its actually quite simple:
http://www.vfaq.com/mods/wayback/BradBauer/engine/valve.html
Here's pictures of where to RTV:
http://www.vfaq.com/mods/wayback/BradBauer/engine/valve.jpg
And why you are at it, you might as well replace your PCV valve since its really simple to take off with the valve cover off ~$3.97:
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=PUR&mfrpartnumber=PV1021&parttype=5&ptset=A
Best of luck.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
