Boost gauge issue
DropSomeMoney
84
Feb 15, 2013
Rockford, Illinois
Ok I hooked up my boost gauge correctly show in the picture. The gauge shows ~25 when at idle. But when I accelerate it jumps to 0 psi and nothing more. I did a vacuum test on my lines and the read at 18. What is my problem? Could it be a bad gauge?
No I do not. It seems one was setup before and was taken off before I bout this vehicle though.
Yes it is.
Here's a full picture.
Ok. I have learned the hard way. I bought this gauge off of eBay. What a pos! I took it out and hooked it up directly to the T and it was off. I only spent $20 on the gauge but I do not like throwing money away at all. No more eBay junk for me. Every time I tapped on it it went to a different setting (Lmfao). I'm just glad I didn't buy anything important off of there.
Drive it safe until you can get a new gauge, boost is not one that can be wrong. If it is not accurate you could lean it out and cause damage to the engine just my .02
Thanks guys! I've been looking into them more. So I've replaced the vacuum hose I cut and going to buy a quality one.
Ok guys. Thanks for your help before. So I bought a new accurate gauge and everything works great. I'm boosting at 15lbs max. My next question is. Should I be boosting this high with no upgrades?
