Boost Gauge Install help
eclipse420ags
259
3
Feb 20, 2010
Martinez, Georgia
Hey guys just wondering if I could T off my boost gauge with the EGR system? Thanks ahead of time for the help.:hmm:
I recommend teeing off the afpr lines and routing the line through the boot for the steering column. If you do this you may want to zip tie the line to a harness underneath the steering wheel so it doesnt get in the way of the pedals if its too long. I can help with any electrical wiring too since i basicly had to figure it out on my own for a gauge pillar so just ask and i can take pics too.
Ok thanks guys I think ill run it to the throttle body I tried the egr and i was having negative boost somehow.
It will be negative because of vacuum. At idle it should be negative always. If it isn't, you tapped into something that doesn't give correct vacuum readings, which is not good.
For ex. On my 4g63t it sits at -18 at idle
I switched to the throttle body hose and when at full boost it just said -10(10 vacuum whatever). Is that major boost leak somewhere? I still here the big whoosh out of the BOV.
Idle at 19 vacuum
This may be a stupid question but the boost will still recognize boost when in neutral right(have mine on jacks right now).
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
