Boost Gauge Bounce
DSM90AWD
DSM Wiseman
2,921
112
Dec 22, 2002
Bear, Delaware
My VDO boost gauge is tapped at the same source as the FPR (#1 intake runner) per the recommendation of the FAQs... but notice that at high RPMs (>5500) the needle bounces 2-3psi making Max Boost difficult to read.
Is this an issue with the gauge itself (i.e. being mechanical) or where it's being tapped into :confused:
I would ask around and see if you could borrow someone's gauge and try that. sounds like yours might be FUBAR'd
Mike :laser:
Thinking about it.. since I used the larger bore black rubber vac line.. it might have a "pinch" in it where it passes thru the A-Pillar ( added my EGT not to long ago so prol happened then).
wow.. that gauge and my Hallman MBC are my original mods from 10 years back OMG
