blown ecu ???
Marceldsm
321
3
Jan 13, 2010
Montreal, QC, Canada
what are the syntoms of a bad ecu ?
im getting code 12 maf
then when i give the car gas it give me code 25 barrometric pressure and tps
even whit the maf plug disconected same story again !!!!!!!!!!!! same code
used 2 1g mafs
repaired wiring harnes to ecu terminal 2 maf signal whas broken
the car runs worst !!!!!
stock boost gauge dosent work
car cant rev past 4000
it days at idlle sometimes
running super rich
used 2 1g mafs
running super rich
sounds like a ground to the ecu or its a bad ecu itself. take the ecu out and open the case. look to see if theres any crusty residu on the board. any black marks or anything that dont look right. someone here on tuners had an ecu fry because of a stray hair got in the ecu. sounded funny to me but i guess it really happend.
I'd be looking at the sensor ground on the ECU. Bottom side of the board.
http://www.dsmtuners.com/forums/tun...55-replaced-broken-mas-now.html#post152235089
open the casing
yes there are signs of burns and melted parts
the ting is its not on the lower side only were the
IC108 looks ready to melt and has cracks there is signs of melting on the ecu c14 looks toost
what my couse that
i will recheck wiring again
and reverify all the grounds
on the ecu side and on the sensors side
yes sir i have that on my ecu
the ting is whay might of cause it in the first place
the old owner instald the safc like an idiot
i tink my 3 month old neeas can do a better job then these dude
ic 108 has some black burn like look on the bord and the resistor itself is burnd
any info and information is welcomed
ANY IDEA WHICH GROUDS SHOOD I CHECK
TANKS
sorry for my bad ENGLISH BROS
ANYY HELP AND IDEAS IS WELCOMED
sorry for that last part
the one leaking is.................107 it looks like it has a burn almost a small melt and it looks like it leakt on the bord
question what is terminal c14????
tanks in advance
IC107 is ISC coils A1 and A2
what my couse these
the isc - idlle speed control ??!!!!!!!!!
i that case what do i do
get a nother idlle speed control ???
my check engine gives me code 12 and when reving code 25 and code for tps
is the ICS RESPONSABLE FOR MY BLOWN ECU AND FOR THESE CODES ???!!!
Im not sure if an isc can cause an ecu to blow.
These ecus are known for having leaking capacitors which when they leak (they all will unless they have been changed) will damage the board. Maybe that is what caused your problems.
There are several places you can send your ecu to be fixed, including Steve who has been helping you so far. I recommend him, he does good work.
I had the exact same symptoms as you and error codes in my car when my ecu went bad.
i orderd a good ecu from somebody off these forum
tanks for the sugestion and help
the question is what happend in the same time
im realy tinking of changing the IDLLE SPEED CONTROL AND CHECK REPAIR ALL GROUND ON THE HARNESS
APPART FROM THAT ANY OTHER SUGESTIONS ???
p`s sorry for my bad english
IC108 is for the Evaporative Purge Solenoid and for the EGR Solenoid.
You sure it's not IC107 that's blown? That's one of the two ISC drivers.
http://www.dsmtuners.com/forums/art...585-troubleshooting-fried-ecu-components.html
Pictures of your ECU would be best. My French is too rusty to use.
whay did it happend new
thats my question becose the car whas working fine before i change the clutch !!!??
let me know what you tink
tanks in advance
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
