ecu ground sensor blown
sharky559
191
Mar 6, 2010
Sanger, California
ok bros so i open the ecu and found that something had blown up. ive read some info about that. but could that cause my injectors not to pules.:hmm:
This will probably cause the car to run super rich if it runs at all. Should be a ton of black smoke and fouled plugs. Also it will probably bog down at about 2k rpms. Just solder a strand of wire across the gap there and you should be good to go as long as you have fixed what caused it to burn.
damn so what could be causing my injectors not to pules. i get spark and the fuel get pressureized but injectors will not shoot. also i tested with a noid lite and nothing
definitely. solder a strand of wire in there and see what happens. if you can't do it and don't know anyone who can, I will do it for free as long as you pay for shipping both ways. send me a PM if you need help.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
