ecu sensor ground help!
97polotalon
50
Sep 12, 2011
pittsburgh, Pennsylvania
so i had a innovative lc1 wired to my ecu sensor ground , for some reason it fried my sensor ground, so i sent the computer back to ecm link and got it repaired, i have since removed the lc1 . today i put the ecu back in the car and started a data log and my coolant temps are reading -74 may map sensors reading 38 psi and my tps volts are 4.88 and 98% or so throttle , i tryed un pluging sensors to try to elimate sensors and nothing seems to work , what all sensors are tied into that sensor ground? and what should i do next ? im compleatly lost . can the wire coming out of the ecu be broken ? any help would be greatly appricated !
Thank you very much for the help, it ended up being the ground wire off the ecu was broken . Works great now
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
