Blowing Radiator (Cooling) Fan Fuses
Bouche Dag
142
Dec 23, 2010
Detroit, Michigan
Car is a 92 AWD.
I noticed my car getting quite hot last night on the way home. Limped it home and checked everything out. I thought the switch had gone bad but that wasn't the case. Replaced it and then found that the fuse on the + terminal for the rad fan was blown.
Replaced it and it blew again after a drive down the block.
It should be noted that I found the overflow tube wrapped around the fan as I was investigating the issue.
The fan still spins somewhat freely (I'd say about 3/4ths of a full revolution when I spin it by hand). And there are no awkward or unusual noises when I directly power the fan with a 12v power source.
Correct me if I'm wrong but the fan should spin a lot more than 3/4-1 revolution when spun by hand? My thoughts: the tube getting caught caused excessive strain on the fan motor, drawing excess amps blowing the fuse. Now that the fan only spins 3/4ths of a revolution it's drawing excessive amps, blowing the fuse.
RESOLVED: The fan motor was bad. See last post.
I ordered a godspeed slim fan (a mod that I wanted to do anyway since my aftermarket j pipe already has clearance issues and since the stock fan is quite the eyesore). I will report back with my findings after install.
Could someone do me a favor and run out to their car and spin their OEM fan by hand and let me know how many revolutions they get? I am just curious to know if my fan is in fact revolving less than it should...
Awesome. I love your confidence. I thought the same since this problem just recently started after the overflow tube got caught.
Sent from my Thunderbolt using Tapatalk
Update:
Installed a new radiator and slim fan (pusher) and voila, no more issues. Plus the engine bay is a lot cleaner without that ugly huge stock fan.
Thanks for the help as always guys!
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
