Mishimoto fan blowing fuses
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
So this mishimoto fan shroud and fans is supposed to be plug and play but they keep blowing the 20a fuse, also a 30a fuse when I test the ac fan. Apparently this is an issue but I haven't found a definitive answer. Slow blow fuse? Add a relay for each fan? I'm so pissed i didn't check these when I first installed them.
Upon further investigation i think the mishimoto harnesses are wired wrong. If you look at the pic the two blue hots on the top of the harness don't match the car harness, of which the blue and blue/white are hots in the forefront of the pic. Basically you'd have to turn the plug sideways to get them to match up. I'm going to try swapping the wires but I have to get more 20a fuses first and I have too many beers in me to go get em
