JuGs
- 674
- 0
- Jul 20, 2008
Marshall,
Wisconsin
98 had mostly stock. Hard ic pipes, 16g turbo, stock injectors and aftermarket exhaust
So first off I been having issues with my car I can't for the life of me figure out. But I'm curious about this issue.
I found ou my cam trigger disc or plate(whichever you want to call it) was 180 out, yes it ran and drove. So I put it the proper way. Now at idle and acceleration I have a miss/blip, specially when warm. I noticed that if I unplug my cam sensor it stops while at idle, and does not die. Cam sensor is new. And if I plug it back in the miss/blip returns. If I shut the car off while unplugged it doesn't start(which is normal) note when the cam trigger disc or plate was 180 out it didn't miss/blip
So my question is. Why for the miss/blip stop once sensor is unplugged?
Only things I can think of is....
Timing off very very slightly
Bad fuel pressure
Bad fuel pressure
