2G Misfire
Garett-Cudworth
Apr 26, 2021
Sheboygan, Wisconsin
Hello all. I recently picked up a built 1999 Mitsubishi Eclipse gsx for my built 300zx. The head gasket was blown and I had to put a new one on. All that being done the engine misfires now so I’m narrowing down my options. Timing is off or bad gap on the spark plugs. Was also wondering what the gap should be at. I hear .028 is eclipse gap but I’m not sure if it changes as my motor is far from stock. Forged internals bored .020 over, kelford 272 cams etc. thank you!
You can neck the plug gaps down to as much as .018". I run 40+ lbs of boost on one car and that is the gap I am using along with BP8ES plugs. What does the car use to tune for the cams and such?
Please post a profile. If we know what's in the car we can provide help.
Some more specific info would help also.
Under what conditions is the misfire?
Can you narrow down a particular cylinder?
What have you checked already?
Can you post a log as you just stated you have ecmlink.
An injector not pulsing would throw a misfire code.
Once at work, everybody else decided they should replace the coil pack, connector, plug wires, plugs, crank sensor, and cam sensor on a Jeep when it was misfiring. And when it was still misfiring, I plugged in my Autel scanner and showed them that injector #4 was not pulsing at all.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
