kpt4321
- 3,383
- 17
- Jul 30, 2002
Originally posted by NewB2dsm Also riching it up to 10:1 or 11:1 umm thats leaning it out guy.
How is that leaning it out? I had to richen it up past 10:1, in order to keep knock away at 18 psi. By lowering the boost, I can run 11:1 or so, which means I don't need to richen it up as much.
if you say riching it up to that point that is taking away fuel making it LEAN, but hey your the expert right?
Huh? Richening it up is adding fuel, making it rich.
Anyway i put my car on a dyno went from 18-20psi my car right now on the wideband is right around 10.5:1 and was getting 19 degrees at 7400rpm in 3rd on the dyno BEFORE my fmic. and egts were right at 1550. Also stock fuel pressure.
Congratulations. Who cares?
I get about the same timing around 7000 rpm, what is your point?
I dont know what you want me to say besides i think you should get a fmic and see what your timing and knock does at the same psi.. that is all.
A FMIC will allow me to run more boost with the same timing, without having to richen it up to avoid knock.
The point is, you seem to think that it's impossible to max out 550's in general, and especially with a smaller setup like mine. I have proved you wrong, and done so several times, fairly easily.
550's can be maxed out with a 14b or a 16g, on pump gas. No question about it, none.
He doesn't have DSMlink so the answer will be no.
