thedean
- 0
- Mar 12, 2012
Pullman,
Washington
As the title states what is the best Material to weld a turbo manifold out of with a mig welder?
Isn't stainless more prone to cracking though? I thought a nice mild-steel mig'd turbo mani was usually considered more resilient?If youre building a mani from scratch its usually best to use stainless, and you can buy stainless wire for a mig using shield. Not sure if they offer a stainless flux type wire
I've had home made mild steel manifolds last as long as some $$ SS manifolds. Little rust on thick steel never hurt anything. For your first manifold there is no reasom to choose anything other than sch 40 1 1/4" mild steel pipe fittings. Elbows, U's and straight pieces.
Pros; easy to cut, easy to shape, easy to weld, cheap to weld, cheap to buy, flows the same, easy to find mild steel flanges.
Cons;Will get unsigtly surface rust, sch 40 mild steel is heavier than sch 10 ss that most manifold makers use.
Welding SS you have to be careful with sheilding gas amd.heat input or you can create a brittle weld or cook the alloy right out of it. It is difficult to cut/fabricate with, and it is not cheap if you make a mistake.
I've made 4 of mild steel and they'veall seen street duty since 2009. I used 1 1/2" back then and that is too big. SCH 40 pipes have weird sizing so 1 1/2" is much larger than 1.5" ID
As you develop your skills consider other materials. Mild works so well for me that I don t even consider stainless as an option due to cost and difficulty of manufacture.
