Battery Install?
gob4sho89
215
Dec 31, 2006
Farmington Hill, Michigan
I am very close to finishing my 6bolt swap. I am waiting on a lift bracket to put the motor in (hopefully tuesday). I have been doing alot of electrical work in the last few days, and I would really like to test it all out before I put the motor and interrior back in.
The things that I have installed are...
Autometer EGT-Boost-Water Temp-Oil Pressure-Air/fuel Gauges
Aem Wideband O2(Gauge-Type UEGO Controller)
HKS Turbo Timer Type 2(Silver one)
fuel pump re-wire
I used a single 30amp relay for the Lighting and power for all the gauges. I used the cig. lighter for a signal for the relay.
Is there any way to hook up the battery to all of the electrical stuff before I put in the engine? If so, How?
Use jumper cables. Connect the negative terminal of the battery to the grounding wire that goes to the firewall and connect the positive terminal to the wires coming from the fuse box.
Thanks, it worked perfect. Should my Turbo timer turn on when the ignition is turned to the on position? It is not, i have the harness pluged in and the ground hooked up, along with the parking brake signal wire. Thanks fo the help:thumb:
