basic upgrades for an auto
turbo_lag92
83
Mar 13, 2010
H20 town, Wisconsin
recently i got a auto awd i have had all 5 speed. just wondering if there is a diffrent type of path for the auto's to get more power and where to start. i did the basic tune up on it already and have a cat back but still nothing to impressive
I'm running an Awd 5 speed eprom ecu in my fwd auto now. I'm getting ready to switch to speed density now. It will work
Does the car blow black smoke, like its rich? That will make them sluggish. Cel on? Back brakes dragging? We need more info.
So how gutless are the autos? I am going to look at one on Thursday and I want to know what to expect...the car is 100% stock.
It isn't that they are gutless, but can be sluggish. Using link, you can add/remove timing for the low RPMs to give them better response, or as stated above, use the 5-speed ECU.
My plan is 5-speed ECU, e316g, 550's, 2gmaf, wally 255, afpr, FMIC. Was real fun in my manual, should be relaxed fun in my new 91 Auto. I only wish the 5-speed ECU was e-Prom, like my Auto ECU is.
At least the TCU is eProm, so it can be modded later.
Get a big trans cooler too and just tap the trans temp gauge sender inline. I would recomend mounting the trans cooler inbetween where the fmic a/c condender and radiator are to use the fan to pull the hot air out.
^^^ As far as I know there is no upgrade for a 13g turbine housing. The 6cm (14b) and 7cm (16g, 20g) housings won't work on a 13g unfortunately.
Only big and evo 3 turbos came with the 7cm turbine housing..
As for the op..Swap out the manifold for 2g, get a 14b, 450 injectors, and manual fpr, ohh and 5 speed ecu..Also the roadsurge auto shift box is a wonderful addition..
He can do 550's and 2g maf right? Just grab a 255 pump and please save up for dsmlink you can only trick the stock ecu so much before timing becomes a issue in your tune.:thumb:
I may be getting a 5 speed now. I have another auto to look at in pittsburgh tomorrow then a 5 speed on Sunday. Both look good but after the car I saw last night I need to see both in person, maybe I am just spoiled by my current dsm but that car last night was in bad bad shape.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
