420A Bad misfire, cylinder 1 dead
Karmah
109
Feb 10, 2015
Hazel Park, Michigan
Hey guys, been messing with my girlfriend's car for a while now. Still can't trace this back to the cause. Cylinder 1 is completely dead; when you pull the spark plug wire out of the cylinder when it's running, no sound is changed at all. We've replaced the spark plugs, wires, coil pack, did timing on it which is dead on with new components, compression tested 180-190 on all cylinders. Not sure what else to do to test for anything else. Any opinions? Car has about 145k miles and is a 1998.
I would get a spark tester ... to be sure that it is sparking ..... I know you said you have new injectors but I would swap injector 1 to cylinder 3 and see if the misfire moves that is real simple you could even move plugs around and see what happens .... even a weak spark will cause a misfire.
If the miss fire doesnt move then its either mechanical or in the wire/electronic and atleast you can start to narrow them down
Put a vacuum gauge on it to look for a valve issue. if you have fuel spark and compression only thing left is air.
Good idea, you could check for spit roller-followers. Pull the valve cover and make sure you don't have any missing valve train pieces
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
