backfire when downshifting
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
Today when I downshifted and immediately accelerated I heard 2 or 3 popping sounds, almost sounded like back firing, is that normal? Never noticed any backfire while letting off gas at higher rpms. I used to drive a mustang GT and it wouldnt ever back fire when accelerating after downshifting however it back fired when at high rpms and I let off the gas. So what gives? Was it the clutch I heard on the eclipse?
Fyi- DSMs all day I no longer drive Mustangs, I eat them :hellyeah:
I would say it's normal, if your mustang had straight pipes you probably would of heard some backfire frequently. Usually I can get mine to let some good crackles out if I feather the pedal a bit.
+1 for DSM over mustang !
So does your backfire when you downshift and accelerate or when you are decelerating?
And theoretically I could somehow ignite this rich backfire to shoot flames right? Because that would be cool LOL
If you wanted to ignite your rich exhaust fumes and could drill and tap a spark plug in right before and muffler and wire to a switch that would allow you to turn on and ignite when you wanted to. I remember finding a kit somewhere that included everything needed. Im sure if you google it you will find it.
It backfires usually if I'm cruising and I get it up to 4-5k and just back off the throttle, so on deceleration but it'll do it on the downshift depending on the RPM level. Although I try to avoid slamming into a downshift so I don't look like I'm rocking out to Korn through downtown. :rocks:
& if you really wanted to, I suppose you could ignite it... either with a kit or a spark plug..:ohdamn:
I have not been able to replicate the back firing for anything. I guess I just dont got it :cry:
Too much time and trouble LOL
Shouldnt have to ignite it, my car shoots flames like crazy, even just cruising on the highway
Well, whats your secret? Lol
