Axle Seal install question
android
Dec 3, 2013
Montpelier, Vermont
Does the little notch on my axle seal have anything to do with the way it's supposed to be installed? Also, is it okay to put a little RTV around the edge of the seal?
i have both manuals and in neither does it dictate the orientation of the seal, but since my assumption is a logical one i assume it would be facing upwards "towards the sky" if so that would be the correct orientation.
further more, that seal is for the drivers side front, and use grease upon installation. And make sure it all the way snug inside.
here is a reference.
http://www.ca.dsm.org/forums/ubbthreads.php?ubb=showflat&Number=354272
and in this thread. All signs point UP!
http://www.dsmtuners.com/threads/remove-7-bolt-awd-auto-trans.469851/
Not to mention, but the transmission pretty much shows you which way its suppose to orient.
No. Yore making an assumption that the old seal is correct. Look inside the seal. Youll notice a hole on the outer lip. This goes down. Factory service manual tells you this. (Hint)
but if you could reference your claim that may help clear things up! Don't you think.
Okay I installed it with the notch on top. I'll know tomorrow when I fill the trans again if it still leaks. Thanks for all the help.
