- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Evo III 16G w/ Ported Turbine Housing
Ported 2g O2 Housing
K&N Filter
Forced Performance 4'' Intake Pipe
VR Speed Factory Front Mount Intercooler
1st Gen Compressor Bypass Valve
NXS Manual Boost Controller
CXRacing All-Aluminum Radiator
Prothane Motor Mount Bushings
STM Shifter Cable Bushings
Energy Suspension Shifter Base Bushings
OEM Shifter Custom Modified for Shorter Throw
EGR Blocked Off and Emissions Removed
not yet installed: 1st Gen Throttle Body Ported to 62mm
- Mods-Engine
- 2.0L 4G63 7-Bolt Block Built By Triple-R Performance:
Eagle 88mm Crank
Eagle 5.9’’ H-Beam Rods
Arias 8.5:1 Pistons .040” oversized
Clevite Main and Rod Bearings
7-bolt Head Built by Triple-R Performance:
3rd Gen Revised Lifters
ENGN BLDR Stainless Steel Valves and Manganese Bronze Guides
Graveyard Motorsports Viton Valve Seals
Brian Crower BC1100 Valve Springs and OEM Retainers
OEM Composite Head Gasket
ARP Head Studs
- Mods-EMS & Logging
- Depo Racing Boost Gauge 0-30 psi
- Mods-Drivetrain
- Competition Clutch Stage 2 Clutch Kit
ACT Streetlite Chromoly Flywheel
Jack's Transmissions Stage 1 Transmission
- Mods-Handling
- Evo MR BBS rims
Hankook Ventus V12 Evo2 245/40/17 tires
Energy Suspension polyurethane bushing kit
adjustable rear toe arms with spherical bearings from 99gst_racer
Removed for weight reduction:
emissions charcoal canister and egr valve
spare tire, tools, jack
sheet metal bracket for the spare tire
front bumper reinforcement bar
a/c compressor, condensor, bracket, dryer, and lines
carpet and some sound deadening tar
all plastic panels, nuts, and bolts behind the front seats
spare tire cover and hatch privacy covers
steel panels from the steering column and glove box
fog lights and their steel brackets
rear windshield wiper arm, motor, and bottle
spoiler
- Parts Wishlist
- Koni yellows & Hypercoils, strut tower & sway bars (front and rear), Evo Brembo rotors & calipers, Porterfield R4-S pads, stainless braided brake lines, DSMlink V3, LC-1 wideband, 3'' exhaust, Aeromotive fuel pressure regulater, Walbro 255, FIC 950cc injectors, 264/272 HKS cams, oil catch cans, black interior, new paint job
