420A Awful grinding from transmission
DrewmHolland
171
36
Apr 11, 2022
franklin, Tennessee
After some hard driving last night my transmission started making an awful racket so I took the starter off and found that every
flywheel bolt came loose but after tightening them up the noise hasn’t stopped, it shifts great through every gear and makes the same noise with and without the clutch in. Please help me
That's one of those noises that is hard to pinpoint from a video.
How loose were the flywheel bolts? Like walking out or just not very tight? If they were loose enough to allow play in the assembly, it has probably destroyed the throwout bearing and possibly some damage to the pressure plate. Unfortunately the only way to check for this is removal of the transmission.
I would go ahead and check the flex plate as well. It is quite thin and would probably warp easily in the scenario of a loose flywheel.
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
